Rear disc. Conversion help!
K-N-2-EK
As the title says im in need of help finding the correct ebrake cables for my rear disc conversion!
I know i need 99-00 parking brake cables does anyone know of a set for sale or the proper part number to order from honda?!
Thanks in advanced, Alex
K-N-2-EK
great source, however thats not the parts i need if you notice in the picture it says number 17 and 18 but that is not the whole cable itself.
JohnS.
BANGARANG
99-00 Si cables. Doesn't look like dealerships carry them anymore. At least majestic honda. Have you tried your local Honda? Perhaps classifieds.
K-N-2-EK
i have tried everything. my only real option anymore is to find used ones hopefully on a car somewhere
Hecz
I really believe Those are the parts that you need.
17 47510-S04-932 WIRE A, R. PARKING BRAKE
18 47560-S04-932 WIRE A, L. PARKING BRAKE
The reason it looks like that cable is short, is because when they designed this drawing - they were not going to redraw the whole line again, rather break it where it actually changes and differs and attach a leader with different part # to it.
Part # 8 and # 5 are more then likely the lines for drums. And notice that you can not even select those numbers because the diagram is for a 99-00 Civic Si
K-N-2-EK
Thank you! i will order those parts then and pray that they are correct. Even though honda dealership claims it would be about 130 per side and also said there are 2 part numbers i need but wont tell me the correct numbers
Hecz
Give the parts department a call to confirm.
JohnS.
BANGARANG
you need the SI e-brake cable and the si master cylinder. also the proportioning valve should be changed as well
99-00 EX (not sure about previous model EX's) and Si share the same master cylinder. But an Si prop valve would be a good idea.
K-N-2-EK
Ive read that it isnt needed to change prop valve as they are the same? If brakes give me hell then i will def do it.
