rear discs/si rear sway bar/si proportioning valve $325skinnyjdawg said:Nice I'm looking to do that in the spring. How much did it set you back? Shouldn't have been too expensive.
skinnyjdawg said:he has an ex silly. He got the discs from an si I assume
damn, I misunderstood... How could I not though????red4 said:swapped my Si rear discs this past weekend,
i have a 97 EX. i pulled the brakes and rear sway bar from an Si down at the local junkyard.MySiIzFaster said:I was hoping this was gabebaumans thread.........
regardless, good looking conversion!!!! err wait a minute, what did you change? Sis come w/rear disc.........
be more clear in your post... dont make people read other things......red4 said:i have a 97 EX. i pulled the brakes and rear sway bar from an Si down at the local junkyard.
LOL.MySiIzFaster said:be more clear in your post... dont make people read other things......
anyway... good job! how long did it take or was that answered?
yeah. like i said, the initial $325 wasn't bad for the conversion, but then i had to start replacing parts and buying more stuff. i probably could have just turned the rotors, and maybe gotten by with using the pads it came with, but i wanted to just replace everything. same with the wheel studs. i took the entire brake assembly apart and cleaned it up, installed new studs, etc. i also bought some new hardware to replace the nasty rusty stuff i had on my car.skinnyjdawg said:wow that's kinda steep
i wish i had air tools, that would have made it a lot easier. some of the bolts were almost impossible to take out.skinnyjdawg said:Nice. Air tools are your friend
At least you had fun doing it, sometimes thats just as important. Now that I think about it I probably would replace everything too so I guess it would be that expensive
no way, man, gotta rep the 96-98, lol.jaypee0930 said:hawt....now convert ur front end to 99-00 front end....it would look sick!
