Rear ITR LCA's and ITR suspension
StreetEuro99
Dont make me reload!
I have a ITR 5 lug kit im looking to install on my 99 si. What im wondering is, if i use the ITR LCA's, can i order a coilover setup for an ITR and use it on all 4 corners for my civic, or will it only work with the rear suspension once the new LCA's are in. Also, is there going to be a difference in hiegth compared to coilovers for my civic and ones for an ITR. Thanks in advance.
Adam
SeanMc300
professional a*****e
are you geting all the suspension pieces from the itr or just the lcas? no you wont see any ride height difference. if you have just the lca's you can still use the civic coilovers.
StreetEuro99
Im only looking to do the ITR 5 lug conversion with the LCA's, i just want to make sure that i can use civic coilovers on all four corners. I might be mistaken but i was under the impression that the lower mount in the rear is different when using ITR LCA's. So i wanted to make sure that if i order a coilover setup for a ITR that it will bolt dirrectly in.
SiGSR
yeaaaay.
Real coilovers that have the strut and springs together as a one-piece will not work, such as the Tein SS. Sleeve coilovers such as Ground Control will work. The rear ITR lca have a different way on how the struts are mounted, so it's the struts that really matters.
If you are putting on coilovers, you would need to find some coilovers that are made for the Type R. If you are just using sleeves, then it'll fit, just make sure to use rear struts that are meant for the Type R.
And ordering a setup for the Type R will guarentee it to fit.
DirtyD
that engine bay looks tight as hell
StreetEuro99
Just so you know, the setup im looking to doo is the tanabe sustec pro SS series, so i figure ill order that for a type r and be set, everyone agree?
