Ummm, you would need to strip off the fabric cover from the rear window and make sure you have a Phillips head screws driver or a flat head screws driver or go inside of the trunk and look above the inside of the trunk and you should see female screw nuts that needs to be take off to pull out the speakers from the inside, and from all that being done you should know how to install from he experience of taking it out. Good luck bro
