Recall info. on 2000 EX Coupe
uncivil
Tsa-la-gi
This is for the 2000 EX Coupe but the link below is for a search on any car.
Automotive Recalls and Technical Service Bulletins for 2000 Honda Civic EX Coupe L4-1590cc 1.6L SOHC (VTEC) MFI.
Provided by ALLDATA
Safety Recalls
TSB Number Issue Date TSB Title 02-031 SEP 02 Recall - Ignition Switch Replacement
02-004 FEB 02 Recall - Rear Seat Belt Buckle Non-Compliance
Service Bulletins
TSB Number Issue Date TSB Title 00-064 AUG 03 Body - Windshield Molding is Deformed
98-018 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
00-088 JUN 03 Brakes - Brake Disc Refinishing Guideline
98-011 APR 03 Keyless Entry - Transmitter ID/Programming
03-020 MAR 03 Engine Controls/Emissions - OBD II DTC's & Monitors
03-016 MAR 03 Engine Controls - Inspection of Idle Speed
03-001 JAN 03 Emissions/Engine Controls - MIL ON/DTC P1457 (EVAP)
02-052 AUG 02 Restraint System - Occupant Detection Initialization
00-095 MAR 02 Body - Moonroof Seal Squeaks
00-006 DEC 01 Suspension - Rear Suspension Clunk/Squeak Noise
98-061 NOV 01 A/T - In-Warranty Exchange Program
00-088 AUG 01 Brake Discs - Refinishing Guidelines
01-040 AUG 01 Engine Rear Main Oil Seal - Leaks
00-012 JUN 01 A/T - Harsh Shifts/Stays in 1st Gear/MIL ON/DTC's Set
01-029 MAY 01 Engine Controls - DTC Capture and Downloading
00-004 MAR 01 Hood - Rattles on Rough Roads
01-024 FEB 01 A/T - Fluid Leak From Converter Housing
99-002 JAN 01 Body - Driver's Power Mirror Vibrates
00-099 DEC 00 Wiring Terminal - Repair Instructions
00-088 NOV 00 Brake Rotor - Refinishing Guidelines
00-089 OCT 00 Supplemental Restraint System - Inspection
00-081 OCT 00 Speedometer - Needle Sticks or Fluctuates
00-068 OCT 00 Ceiling Light - Intermittently or Totally Inoperative
00-063 AUG 00 Special Tool - Chassis EAR(TM), Diagnostic Tool
00-057 JUL 00 CD Player - Sound Cuts Out at High Volume
99-053 JUN 00 Immobilizer Key - Key Code Duplicator
00-012 JUN 00 A/T - Harsh Shifts/MIL ON DTC P0370 & P0715 Set
00-031 MAY 00 Windshield Wipers - Won't Park or Shut Off
00-044 MAY 00 Quarter Glass - Rattle/Squeak While Driving
99-018 APR 00 Required Special Tools And Equipment,
97-021 MAR 00 Front Windows - Bind or Out of Run Channel
00-006 MAR 00 Rear Suspension - Clunk Noise
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-015 MAR 00 Audio Unit with CD Player/Changer - Error Codes
00-032 MAR 00 Paint Codes
00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
00-025 FEB 00 Coolant Leak From Reservoir
99-073 FEB 00 Driver's Foot Rest - Popping Noise
00-007 FEB 00 Fuse Box Cover - Falls Off
97-009 FEB 00 Ignition Switch - Key Cannot Be Removed
98-079 FEB 00 Rear Hat Shelf - Rattle/Buzzing Noise
00-021 FEB 00 Windshield - Wind Noise (Whistle)
97-015 DEC 99 Service Publications - Availability & Ordering
99-089 NOV 99 Hood Release Handle - Broken
99-094 NOV 99 Poor Radio Reception
98-031 NOV 99 Aftermarket On Board Diagnostic (OBD) || Tester
99-062 OCT 99 Paint Damage From Environmental Fallout
99-030 MAY 99 Recommended Materials
98-051 AUG 98 Special Tool Loan Program
[ Select a different engine | Select a different model | Select a different make | Select a different year ]
ALLDATA has obtained this information from the original equipment manufacturers and others and ALLDATA believes it to be reliable. However, ALLDATA makes no warranty regarding the information, express or implied, and accepts no responsibility for the accurancy or completeness of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or misuse of this information, including, but not limited to, any direct, indirect, incidental, special or consequential damages arising out of the use or inability to use this information.
Viton® is a registered trademark of DuPont Dow Elastomers
Loctite® is a registered trademark of Loctite Corp.
Teflon® is a registered trademark of E.I. DuPont de Nours & Co., Inc.
Dexron® is a registered trademark of General Motors Corporation.
Bendix® is a registered trademark of Allied Signal, Inc.
Goodwrench® is a registered trademark of General Motors Corporation.
Helicoil® is a registered trademark of Emhart Industries Inc.
Plastigage® is a registered trademark of AE Clevite, Inc.
Torx® is a registered trademark of Camcar Div. of Textron, Inc.
Motorcraft® is a registered trademark of Ford Motor Company.
Havoline® is a registered trademark of Texaco Lubricants Co.
DEX-COOL® is a registered trademark of ACDelco, Inc.
Optikleen® is a registered trademark of General Motors Corporation.
Lubriplate® is a registered trademark of Fiske Brothers Refining Co.
Copyright © 1996-2001 ALLDATA LLC. All Rights Reserved.
<CLICK>
EluSive2K
OG Club Civic DJ!!!
a lil off topic, but hey i love the avatar. LOL!!
anfrey
OG スバリスト
if you join honda's ownerlink site, they'll tell u what recalls apply to your car... so far my 00 ej8 is clear.
Rick James
you talking bout that thing from honda where u enter ur vin number and it tells u bout recall s**t
anfrey
OG スバリスト
yes, it also keeps you updated on new honda stuff. ..
