I have new Halo projectors and hit a pot hole really hard, the reflector fell off and is sitting in my headlight housing. I was wondering if anyone knows how hard it is to get in there and fix it?
I would call the company you bought them from and complain, see if they will send you new ones...If not, you could heat the lights up and pull the lights apart....Heating them up requires putting them in the oven and baking them...good luckOriginally posted by civicdrvr22
Yes, here it is...This is for stock headlights, but I beleive it should work the same because all you are doing basically is heating the calking up to pull them apart...So here...Originally posted by CFactor
ya streetciv didn't u post up a shortened how to in another post?
That would be some good information to have.....I know the stock headlights, all their parts can take it, well because I did and there are alot of other people that have, but the plastic list would be awesomeOriginally posted by samuri
I'll try to find out what plastics are safe or not. A friend of mine works for Hella designing headlamps, so i'll ask him, as it should say what plastics they're made from on the actual parts.
eg. On the Cover it sould say - PC
\Originally posted by civicdrvr22
Thanks all for your help, i am gonna try and get them replaced. But if i can't do that then i may have to either try and fix those or do back to the stock headlights and replace the amber refector in that.
WOW, thanks a bunch man keep me updated. The info will definently come in handy as soon as i decide what i am going to be doing.Originally posted by samuri
Well ive spoken to my friend regarding the plastics, but its not as striaght forward as 'what plastic is safe'.
He says it depands not only on the type of plastic but wether its had any treatment or covering to improve the heat properties.
He said the cover is made from Polycarbonate (PC) but has a load of treatments to make it withstand the heat from the bulbs/sun and to stop it from gonig yellow, which all increase the melting temp so will be safe. Its the housing that'll cause the problem as it isnt subjected to the same amaount as heat so may be made of a lower grade of PC.
So you see it gets very difficult to say, especially with any certanity, what will be safe or not.
He is going to investigate it though, to see common plastics and grades used and email me some details, so i'll post the info as soon as i get it next week.
Sorry i havent got any solid info.![]()
This is very true, Im still interested to see if aftermarket lights could handle the oven thoughOriginally posted by anfrey
the only solid info i have at the moment, is that stock headlights can handle it
ya, 10-15 minutes depending on how good your oven is...Older ovens tend to take a slight bit longer than new onesOriginally posted by eminemslm0
200 degress in the oven for 10 min does it just perfect
