Just a guide to the more popular tires out right now.
If you don't see a tire listed and you believe it to be
popular, let me know and I'll add to this list as I see fit.
Also, I appologize for the long descriptions. They do,
however, give you an in-depth idea of what each tire
is like.
BFGoodrich g-Force T/A KDW
BFGoodrich g-Force T/A drag
BFGoodrich Scorcher T/A
Bridgestone/Firestone Firehawk Indy 500
Bridgestone/Firestone Potenza RE950
Continental ContiSportContact
Continental ContiTouringContact
Continental ContiExtremeContact
Falken Azenis Sport
Falken Azenis ST-115
Falken GRB FK-451
Goodyear Eagle F1
Hankook Ventus Sport K104
Best tires for your needs <<Part Two>>
Best tires for your needs <<Part Three>>
is like.
- Incredible dry traction with unflappable wet
weather control. Long treadlife. Smooth, quiet
ride. In sizes that make it the perfect choice for
most of today's hottest sports coupes, sedans,
and sport trucks. Y-speed rated (up to 186 mph).
- All-new version of the world's first DOT-approved
street legal drag radial brings hero-making traction
and control to the strip. Redesigned to deliver broader
peak performance during launch. Maximum straight-line
traction. Fully streetable.
- The world's first and only real color high-performance
tire delivers control you can feel and see. Ultra high level
of handling. Full-tread depth color ribs refresh as they wear.
Available in Yellow, Blue,Black and Red.
- g-Force T/A KD is the new force in performance tires.
The result of an entirely new approach to ultra-high
performance tire design g-Force T/A KD is optimized for
dry traction on the street. It's the ultimate expression of
BFGoordich brand Traction/Advantage, designed to deliver
near R-compound levels of traction and handling in a more
streetable tire. Intended for use on the world's best sports
cars, this tire ensures exceptional control and inspires
supreme confidence.
- Featuring the UNI-T, this tire uses a super computer
to help combine tread design, shape, materials, and
construction successfully.The Firehawk Indy 500 pays
tribute to the performance of the Firehawk Indy Racing
Slick.
- The Bridgestone Potenza RE950 is a high performance
all-season tire that was developed to meet the needs of
the drivers of sports cars, coupes and sedans by blending
dry, wet and year-round traction, even in light snow. The
Potenza RE950 is Bridgestone’s first tire in America to
feature UNI-T AQ II technology which uses advanced
compound and construction features to enhance and
preserve wet traction through the tire’s life. The Potenza
RE950 handles wet … even as it wears.
- The Sport Contact is Continental's latest entry into
the ultra high performance market. Its asymmetrical
tread design is designed to deliver precise and instant
response while enhancing treadwear. Available in W
and Z speed ratings, this tire provides excellent wet
traction and is an approved original equipment tire on
the world famous Porsche 911.
- The ContiTouringContact CH95 represents Continental's
most advanced all-season tire technology. The tread pattern
features 3 wide center grooves for efficient water drainage
and large, stable outer tread blocks. The tread pattern is also
heavily siped for good traction in light snow. With such good
all-around performance, it's no wonder the CH95 is being
selected as original equipment on many European cars like
the Mercedes-Benz C- and E-class, Audi A4 and A6, and
the BMW 3, 5 and 7 series.
- The ContiExtremeContact's silica-based, high-grip,
all-season tread compound is molded into an independent
tread block design that features Continental's "Tri-Net" and
"Shark Fin Bio-Mechanics" technologies. Tri-Net's three
networks result in a tread design that combines a strong
network for dry road handling stability, a flexible network
for wet grip, and a cold temp network for snow grip. The
"Shark Fin Bio-Mechanics" directional tread design is inspired
by the rounded edges of a shark's fin that allows for the
smooth fluid flow that helps it glide smoothly through water
with minimum friction. Internally, the ContiExtremeContact's
twin steel belts are reinforced with spirally wound jointless
nylon cap plies to provide long term integrity under high
speed conditions while it reduces weight and helps provide
more uniform ride quality.
Falken Azenis Sport
- Maximum transfer of braking and acceleration to the pavement.
Stiff sidewalls for control and a firm ride.
Solid tread blocks for excellent dry-weather performance.
Sidewall and shoulder block reinforcement for long life.
Excellent endurance and durability, high heat resistance.
- Falken Tire introduces the new silent running Azenis
ST-115 tire. The company considers it the ultimate in silent
running/noise reducing/ultra high performance because
of the engineering breakthroughs that its staff created
including incorporating micro-vacuum capsules into the
compound that literally suck out road noise. In addition to
reducing road noise, the capsules also contribute to a higher
stiffness on the base tread for improved handling ability.
The new Azenis ST-115 tire from Falken virtually eliminates
road noise, and is preferred by sound-off aficionados who
enjoy megawatt super high-end audio systems. By eliminating
road noise the ST-115 allows the system's crisp highs and
deep bass to be heard true...letting you hear what you want to hear.
The tire is attacked performance features including wide twin wide
circumferential grooves, which excellent wet-weather performance.
The ST115 also sports an aggressive appearance with its low
profile, unique tread pattern. It also features sidewall and
shoulder block for longer life.
Falken GRB FK-451
- Exotic looks, style and performance are keys to the new GRB FK-451.
Deep lateral grooves and directional tread deliver great curb appeal as
well as excellent wet traction. A new tread compound steps up to
deliver the dry traction you want. Integrated sidewall ridge protects
your rim investment. Available in ultra low profiles at surprisingly
affordable prices.
Goodyear Eagle F1
- Goodyear introduced its first Eagle F1 tires as original equipment
on the 200 mph McLaren F1 in 1995. Since then they’ve added
Eagle F1 Fiorano tires specifically developed for several Ferrari
models, as well as, Eagle F1 Supercar tires for the Shelby Series 1
and Chevrolet Corvette ZO6.
- Hankook Tires has been making tires for almost 60 years.
They have become one of the largest tire manufacturers in the
world. Hankook enjoys O.E. relationships with several auto
manufacturers. Why is O.E. so important? It is a sign of
Hankook's technological success, superior quality, and value.
The Ventus Sport K104 is a Y-speed rated, ultra-high
performance tire designed with racing technology. The tread
and silica compound provides superior control and
responsiveness required for extreme driving conditions.
