I have a 99 Ex Coupe, it hit the 116,800 mile marker today
I bought it used and the only problems with the car at the time of purchase were cosmetic. I do change the oil every 3k like suggested. I've done all the recommended maintenance except for the 115k, (can't afford it right now).
The car usually runs fine from what I can tell.
Current problems:
The suspension needs replacing, but I'm waiting until I can afford to get the suspension I really want.
Just noticed the last time I changed my oil that I might have a slight oil leak, but I'm not positive.
I know that the rubber connecting/cover piece for the shift rod into the tranny has a hole and needs replacing asap. (forgive my lack of knowledge on proper names)
My drivers side power mirror rattles if the vehicle is on and the door is open, this just started two weeks ago.
Ever since my drivers side window was busted I have more than normal wind noise at higher speeds.
My short shifter rattles when at idle or under high excelleration, but only ever since the short shifter and polyurethane bushings were installed.
I am gonna need new bushings all around soon if not already.
Sometimes the engine struggles to start up, only does this everyone once in awhile, like every 2 months or so, not sure why.... ??
Oh yea, and some of the interior lights need replacing.
I do push the engine sometimes, more than I should. I'm sure there is some internal work needing to be done, especialy concidering the number of miles on the engine. The car is my daily driver and I also use it for work, deliveries, so it gets a work out everyday, non-stop, stop and go driving
*Edit* Forgot to add that I have had to replace the battery, spark plugs and some other parts that are critical to engine performance, dealer did it for me, don't remember which parts at the moment though... Nonetheless it was not cheap.
