Ok, so tonight at work I began to think about my set up and the long term effects of my engine. Thinking about what I should really do with it.
1. This car is my daily driver, however I do have a second car.
2. This car stands out like a damn thumb.
3. This car has tons of time and money into it.
4. I want to own 3/4 of the B's on the streets
5. Car has new timing belt/water pump/oil pump/all bearings/all gaskets.
6. Will not be sleeved or posted.
Looking at the RELIABILITY issues as well as the LONGEVITY issues. Now I do realize that a D can be picked up extremely cheap, however who wants to build something to rebuild that samething in a couple of months or even a year. I am a mekanik but damn I do that all night long at work I really dont want to do it when I get home everyday, ya know.
My set up:
D16Y8
F-Max Turbo Kit---4 stock injectors/2- 650cfm lucas injectors
Spearco front mount intercooler
MSD-SCI Ignition
MSD Blaster coil/cap
Turbo XS 2 stage boost controller
Nology plug wires
Revolution cat-back exhaust
DC intake
Clutchmasters Stage 3
Apexi V-AFC---minor quick tuning
I had the car dynoed a while back with all of the above add=ons, @ 6psi boost I hit 146whp and @ 12psi I hit 197whp.
2004 winter build up
Blockgaurd
Clutchmasters flywheel
AEM EMS------plug n play for those of you who dont know what that is.
AEM pulleys------didnt go with the URs
Exospeed head----3 way/cam grind-turbo/port-polish/valve seals
Full Btm end---JE pistons/Eagle rods/ARP bolts/all other crap
Walbro fuel pump
I run 6 psi normally and a GUESSED figure on HP is about 210whp when completed @ 6psi. When I flip the little switch it reaches 12 psi, GUESSED figure for that would be around 250whp @ 12psi.
Anyway, I'm looking for advice here from all of you, I will be running 6psi on a normal basis and when some ex-commey bastard wants to f**k with me I can switch to the 12.
Will this all work out for me in the end or am I going to f*ck myself over and might as well pick up a new motor soon??? Regardless my gear is already bought.............
http://www.teamtrio.com/greg.htm
Thanks for all the advice/help whatever it is.
G FLICK
My set up:
D16Y8
MSD-SCI Ignition
Nology plug wires
DC intake
Blockgaurd
Walbro fuel pump
G FLICK
