removing gauge needles & red coloring on gauges
clover99b18c1
i need to know how to remove both the needles from an 01 civic gauge cluster and how to, if possible, remove the red coloring from the back of the gauges. heard there was a diy floating around here somewhere but i can't find it for the life of me.
Thanks,
Ben
Simply.Smooth
you can pry the needles of using a flat head screwdriver just put it under and twist it but be VERY CAREFULL as they are Easy to break
DetainedCivic
I haz SR20
Thanks,
Ben
Why can't you just leave it alone :what:
VTi_ME
Dont do it or else u are gonna regret it
Tom
honda.co.jp
Simple you can't!
I don't care what any other person thinks, it's not possible unless you want to replace a whole gauge.
c_diddy
drove through a tree
Tom said:
Simple you can't!
:word: even if you did get them out and back in, it wouldn't work right.
Bzart
To pull the needles off use 2 flathead screw drivers and pry up on opposite sides with steady pressure. Now the problem that you will face is when you go to put them back on. How will you know where the needle is supposed to point?
