Christopher Gregory
Hello all,
INITIAL PROBLEM:
My 1997 EK9 SI (Canada) has a couple small oil leaks and I'm slowly fixing them one by one, and today was the VTEC solenoid's turn. After a good amount of video tutorials I pulled it out.
PROCEDURE:
It was a straightforward job as I expected, pulled out the old cracked gaskets, cleaned parts with carb. spray, put the new gaskets from the stealership in and put is back together.
NEW PROBLEM:
After bolting it on and plugging everything back in, I started my car and now I have a CEL.
TROUBLESHOOTING:
I checked the solenoid by sticking a wire in the plug and connecting it to the car battery and it does engage.
Took the car out for a quick spin, doesn't feel much different, still revs past 6000 rpm, exhaust smells like its burning oil in the higher rev range, so I take it the VTEC is not kicking in, but I don't see anything incorrect with my procedure that would cause it to stop working. Checked the forums, but I haven't been able to find the exact problem I'm having.
Any ideas? Post a link to a thread if there is one that already covers this. I will be buying an OBD II sensor tomorrow and post the code. Thanks.
INITIAL PROBLEM:
PROCEDURE:
NEW PROBLEM:
TROUBLESHOOTING:
