Hey all
Ok well let me first say I suck with electrical..my friend did most of the wiring on my fog lights I just mounted them on the bumper =P..
anyway My driver side fog bulb went out yesterday and I took the bumper off to investigate. I figured out that you can't replace it from the front, you have to remove the rear housing and 600 other screws. So then bought an H3 bulb down at kragen, I assume its the same one they look the same. Anyways it has a white nylon wire coming out of it, about an inch or two long, with a prong on the end of it. But my current fogs have both a black nylon wire and a white nylon wire. And they are all taped up and they go into a plastic socket (male), which then runs up through the engine bay of course.
My question is how do I put the new bulb in. Or in other words how many noobs does it take to screw in a light bulb. It for an EG front end if that helps.
Help is appreciated
Help is appreciated
