reset the computer
wake_rider
does anyone know how to reset the computer in our cars? With my truck you have to turn the ignition on w/o starting the car and then pump the gas 10 times. Anything like that w/ our car?
knockoff
you can call me ABE
do a search...
"resetting the ECU"
Sprecher
Experimental
There's a fuse in the engine compartment. It's a fuse that shares the same curcuit as the radio (dumb). Pull the fuse out for 10 seconds then replace. Whala!
racecarl
world war wilson
disconnect the negative terminal for a second then just pop it back on then presto magnific! good to go.
banzai
Exit Speed Garage
yea, all you have to do is disconnect the battery. What are you trying to do? Is there a problem?
DirtyD
you dont need a problem to reset the ECU, you should reset it everyimte you put on a new mod
wake_rider
don't disconnect the battery unless you want to lose all your presets on your radio and the time. just do the fuse trick, much easier.
