Automobile Safety Tips
These safety instructions for drivers and passengers in a vehicle where provided by Attorney Gordon Johnson:
1. Never ride in a moving vehicle with the seat back reclined. Sitting in an excessively reclined position can be dangerous. You could slide under the seatbelt in a collision. If you slide under it, the belt would apply force at the abdomen and neck. This could result in serious or even fatal injuries.
2. Never store loose items in the rear window or in the vehicle in general, they could cause injury in a collision.
3. Make sure your lapbelt is snug against your hips, not your abdomen. The shoulder portion should be located as close to the middle of your shoulder and should not touch your neck.
4. Pregnant women should position the seatbelt as low across the hips as possible, with the shoulder portion correctly adjusted to avoid contact with the abdomen.
5. Never wear the shoulder belt under your arm, against your neck or off your shoulder. In a crash, your body would move too far forward. That would increase the chance of head and neck injuries. The belt would also apply too much force to the ribs and abdomen, which could severely injure internal organs such as your liver or spleen.
6. Belts should never be worn twisted. In a crash, you wouldn’t have the full width of the belt to take impact forces. The twisted belt against your body could cause injuries.
7. When driving a vehicle with airbags:
* Wear your seatbelt correctly, snugging up the lapbelt by pulling on the shoulder portion.
* Adjust your seat rearward as far as possible, still permitting proper operation of vehicle controls. This is important to both driver and front passenger.
* Do not lean with your head or chest close to the steering wheel or dashboard.
* Keep hands on the outside of the steering rim. Placing hands and arms inside the steering rim can increase the risk and potential severity of hand/arm injuries when the airbags inflate.
* Never allow a child under the age of twelve to ride in the front seat, unless your vehicle is equipped with a system which deactivates the passenger side airbag. Make sure the child sitting in the rear seat has a proper positioning of the restraints. If the child is too small to wear a seatbelt correctly, use an approved booster seat or carseat. When using a carseat, follow manufacturers’ instructions on tethering the seat.
* Remember that airbags do not deploy in some situations, so it is important to wear seatbelts. The type of crashes in which an airbag would not deploy include some frontal impacts, angled impacts, roll-overs, some side impacts, rear collisions and other accidents without sufficient forces.
* Airbags are designed for a one-time use only and must be replaced once deployed. In that event, it is important to examine the integrity of the seatbelts as well.
8. Don't drink and drive, it is one of the leading causes of motor vehicle accidents that often lead to brain injuries or death.
