Rolling rear fenders
SRLNCLT
mad jdm yo
K, as most of you probably know I just put 17's on. When I go over a bump the rear tires rub ever so lightly on the rear fenders. I know I've heard of people doing it so how do I roll the rear fenders? I think I remember one buy saying he use a baseball bat? So do I just bend the lip up, is that all rolling the fender is?
thanks
L.
2kstreetcivic
Runnin to Redline
thanks
L.
yes you do use a baseball bat...that is the cheapest way...I dont know step by step, but the baseball bat works
codyj86
ya... but if you have the money (or the talent) i would get them tucked and rolled. have a body shop do it. but if you don't have money or talent (like me) then use a bat. =)
civic1582
CCSC #86
yes please explain. Something about taking a baseball bat to my civic just doesn't sound right at all
codyj86
i don't know exactly how but as i understand, you put the bat between your fender and your wheel and pull up at the same time roll your car back and forth to bend the fender out. don't do it too much in one spot and do alot more searching for you start to do that.
Je
the white hatch
i think you just start at the rear and let your car roll back once and that should do it. Most car shops around here wont do it incase they damage it, but i have never tried mine.
ZimZimma13
Search the How to and the how to/DIY on other sites if there isnt one here. Ive seen one somewhere before.
Personally I had that problem with my 17s at first too, but I just run -1 degree of camber in the back and rotate my tires every 3k or so at my oil changes so the tires dont get worn down too much :D
SRLNCLT
mad jdm yo
ZimZimma13, yeah it just rubs when I go over bumps. It rumbs on the rubber in the wheels wells. Is that what yours did/does and is yours still doing it? I think tomorrow I'm just gonna gut under there with some pliers and try to bend it up a little cuz mine isn't rubbin to bad.
L.
anekin007
Unregistered User
try smaller wheels, i can't get anything bigger then 15, if i do, it will rub in the front and back especially when i turn. i just love them curvy roads :D
ZimZimma13
L.
Mine was rubbing that little lip that there is on the wheel well, like if you reach underneath it sorta sticks out a little bit, so the -1 degree camber took care of clearing that for me. It depends on the offset of your wheels if yours will be solved by doing the same thing I did.
ner0x
SOHC MY DOHC
or you can do what i do.... buy some 15'' spoonz =p
JDM Juice
Is JDM Juice real?
Uh.. rolling your car back and forth? Baseball bat?! I didn't do that with my fenders... the only thing my friend and I did was use some heavy duty wire cutters (they're not wire cutters but I hope you get the idea), we cut the fender (6 inches total in length--- just along the area it was rubbing) made an incision every 2 inches or so and used a hammer to fold the fender on itself. I've only had to do one side... maybe my alignment has something to do with it, but it got the job done so I'm happy.
