RPM really low
somejaykid
i'm a mod now
:evil: alright i have a 92 hatcback and for some reason my rpm idles really really low like it's sitting in the 1 rpm, it pisses me off so bad cause i keep thinking that the car would just die down, but sometimes when i'm sitting in a traffic or what not the idle goes up, if anyone know what's wrong with it please tell me, alright thanks for the time to read this.
p.s. do you think getting a engine in a junkyard is a good idea, tell me it is or not
kellog
well could you tell us the modle of your car, wat motor is in it. also if you pop the hod of your car there should be a sticker saying were the car should idle, i know mine says 500rpm for manual and 400 or 600 for auto....not quiet sure on the auto.
somejaykid
i'm a mod now
well my car is a 92 hatchback vx and i got a exhaust without the cat
elusivehomies
Too Tall
check your fuel lines and your idol screw and your cat has nothing to do with it
somejaykid
i'm a mod now
where can i find my idol screw
Je
the white hatch
mines a 92 vx and it idles below 1, im not trippin
somejaykid
i'm a mod now
same here any ideas why it does that
FastJ
yeah dude i have a '93 civic sedan and it idles at below 1000 usually. sometimes when im sitten at a red light with the music barely on i cant even hear the engine cause it idles so low. I dont think anything's wrong with it. If u look at the trottle body though, there is a wire leading to this lever ( i cant recall what it is called, i know that sounds stupid) that when u push it the engine revs. Just adjust the tension in the wire and it should idle higher. You'll probably use more gas this way though so dont set it too high, just enough so it idles over 1000. SOrry i couldnt be more technical, but thats all i know. I know that will adjust the idling.
IGotASlowCivic
Yeah Im slow... So?
Woah. I'll have to look at that... cause mine idles at like 1200-1500 :(
jasonsa
!!!TILA!!!
idle problem
i wouldnt mess with the throttle cable. on the tb there will be a screw that is like sunk in a little. turn that and the idle will go up and down. =)
streetdemon
yea dont mess with the throttle cable i did once and the car sometimes idled 1500 and sometimes 300 so adjust the screw
somejaykid
i'm a mod now
what screw is that then, can you be more specific thanks
Je
the white hatch
^^ people just said not to mess with it lol, and you wanna know where it is??
As long as ur ride aint shutting down at idle your ok i would think
soswank
Dentist in the making
I've got a 98 ex, mine idles at around 800.
x007den
New User
i wouldn't worry about it either, you can change your fuel filter if you feel like u gotta do something.
5thGenCoupe
the FAA owns me
Hey y'all
DO NOT adjust your throttle cable to raise the idle speed!
To do that you use the idle adjusting screw on the TB which some other people have mentioned its right where the air intake duct meets the TB. I forget whether its facing the right or left side of the engine bay but i'll get back to ya. As for the idling problem, do check your fuel filter if it hasn't been changed according to the maintenance schedule but more likely (and this was my case) its due to a weak spark. Honda is notorious for making shitty distributors so i'd have the ICM (ignition control module), Ignition coil, plug wires and plugs checked out.
-Mike
PS: Anyone have pics of the stock TB?
SiGSR
yeaaaay.
Idle speed should be around 750(+ /- 50)rpm. It is probably the fan coming on when your sitting in traffic that causes the idle to go up.
