irawkian_EK9
ok for some reason my RPMs arent going above 4500... soon as i hit 4500 or 5K it bounces off the rev limiter.. Im running a 99 EX 5-Speed ECU and D15B VTEC Swap.. 5 Speed... Any suggestions...
You double clutched it? Why.. your transmission has synchros; there's no need to double clutch when driving....other then once when I double clutched and punched it...
He would dummy light for sure. He isn't getting crossover because he doesn't have a computer crossover, he has a manual crossover(horn button)simple check. check your oil. if your oil is low your car won't crossover into VTEC. Could be a simpler solution .
