rpms go up if pump the brakes
ugadawg187
My 97 civic EX 5 speed had a CEL P0505 i think for the IACV so i cleaned it only then to have jumping idle. I replaced it with a brand new IACV. Now when you turn the a/c on you can hear the IACV click rpm's jump to 1200 but quickly fall down to around 600-700rpms. It idles at 900 rpms with the a/c off. I heard the brake booster or master cylinder could cause a vaccum leak so i pumped the breaks & it idles up. Push the brake pedal & nothing happens until you let off then it idles up & back down. Any input on this?
CHILD
All Day, All JDM
That's normal with a brake booster line in use if the cel code issue has been resolved
MistahJuice
100% real juice
Brake boosters do exactly what they sound like, they multiply the force you exert on the pedal to help your brakes work properly. They do this using the vacuum caused by your engine so when you step on the brake, the idle needs to go up to compensate for it using part of the vacuum your car creates.
CHYEAHMAYNE
This happens only after clearing P0505, or is it normal all the time?
