that's exactly my concern. i don't feel like removing my fender and snaking the wires using that rubber thing, but i guess i have to since it's the only way to do it.The stock wires are s**t, only like 18 g i think. Go to bestbuy and get 16g. I'm doing the same thing my amp comes this week. How are you going to get that wire through the snake in the front doors?
not really, i'm thinking about running the wires from amp to head unit, then connect it to existing wire that connects to my current speakers.So you want to pull out all the stock wiring and re-use it? Just use new better wiring. It'll be a lot easier.
correct by the door bottom floor. remove them panels and you should see the plastic tube that connects to the door. stick the wire cables into the hole into the doors...you should see it and i highly recommend better wires, because its for the sound and quality. (that is the main reason of all this after market stuff anyways). "once you do it, do it properly or you will have to redo and sometimes it cost more to fix than just getting the right item, the first time".You dont have to remove your fender, you should be able to do it just by taking an interior panel off.
grounding the amps would best be anything...i did mines at my shocks in my trunk.. the two bolt that hold my shock inside my trunk. speaker wires...just get at least 13-15 feet for speakers, and for subs get at lease 8 gauge wires. the power and ground should be at lease 4 gauge..ground should be bigger because it gives more power to the amps, and get a better batter like the D51 optima yellow top battery. its deep cycle...also, how long should i get the speaker wire, power cable, and remote wire if i mount my amps on the trunk? where would be the best place to ground the amps?
i depends how much he wants to run....if i was to buy amps i would buy sundown amps...they are the best i heard.I don't think he needs a huge distribution block like that....I don't think he plans on running that much power. I'm telling ya man RF kit w/ power and ground distribution blocks, fuses, RCA's, speaker wire, connectors, power and ground wire, remote wire, totally worth it and good quality. Not a bank buster.
yea, i'll get one of those optima yellow top battery eventually once this one ran out of power. but now, i'd rather invest my limited budget for decent wire setup.grounding the amps would best be anything...i did mines at my shocks in my trunk.. the two bolt that hold my shock inside my trunk. speaker wires...just get at least 13-15 feet for speakers, and for subs get at lease 8 gauge wires. the power and ground should be at lease 4 gauge..ground should be bigger because it gives more power to the amps, and get a better batter like the D51 optima yellow top battery. its deep cycle...
how can i get one of those rockford kit? that would make my life easier, monster and tsunami doesn't seem to have amp wiring kit, only stinger has amp wiring kit. rockford makes stuff as good as monster.arent you just going to get a wiring kit? they have everything the rockford fosgate ones have like 40ft of speaker wire which should be plenty and plenty of length for the power, ground, and remotes. Um I grounded mine to the tail light but any bolt will do as long as its got a clean contact to bare metal. If you have to just drill a hole in your wheel well and put a bolt there to be the ground.
what's that distribution block for? someone explained to me before but i forgot the purpose of getting that thing.i ran my wires through the middle of my car. it was all not that big of a deal. you should get a combo distribution block from directed or streetwires..i got mines from street wires like 4 years ago for $100.00. yeah good deal for it though in those days...now it be like 80 bucks....let see if i can find pics.
http://akamaipix.crutchfield.com/products/2002/211/h211CBR44A-blue_dmp.jpg
there thats the one i got...well let me know if you need anything....
isn't the battery located on the passenger side?I ran the amp power wire down the drivers side and all the speaker wire down the passenger side of the car.
cool. not all people like subs. they like the harsh twikking. distribution block is the block made to split power...like for your power wire it connects into the distribution block input and out the output into 10-8 gauge wires, which you can hook up to how many output an distribution block has into the amps, equalizers, and crossover. depending how you want it. the ground goes the same. (the power has fuses to protect your amps from blowing.yea, i'll get one of those optima yellow top battery eventually once this one ran out of power. but now, i'd rather invest my limited budget for decent wire setup.
umm, i don't have any subwoofer system, and never been a fan of subwoofer. i'm just trying to power my speakers with amplifiers.
i'm not a big fan of drilling a hole in my car, so is there anywhere close that i can mount the grounds other than suspension? i know the bolt on the suspension is a b***h to remove.
yes the battery is on the passenger sideyea, i'll get one of those optima yellow top battery eventually once this one ran out of power. but now, i'd rather invest my limited budget for decent wire setup.
so if im getting a component speakers in the future, do i need one of these to power the crossovers later on?cool. not all people like subs. they like the harsh twikking. distribution block is the block made to split power...like for your power wire it connects into the distribution block input and out the output into 10-8 gauge wires, which you can hook up to how many output an distribution block has into the amps, equalizers, and crossover. depending how you want it. the ground goes the same. (the power has fuses to protect your amps from blowing.
