I bought my '96 DX w/ a Y8 head on it, but not wired up. I recently bought a knock sensor so today I got that in and ran the VTEC switch and pressure sensor wires, etc...so I ran the 3 to the ECU pinouts and popped in my P2P ECU and at idle it's jumping back and forth from 1500-1700 HARD. Just surging basically. There are NO vaccuum leaks, and when I toss the stock P2E ECU in it runs normal again, so I know it's wiring. ALL my connections are solid, but I talked to the PO and he told me it's a Y7 TB on the Y8 intake manifold. On top I can see a 3-wire IACV, but it's spliced into / onto a 2-wire one that has a resistor in it. The ECU pinouts have something in A13 and A14, so it looks like it's a 2-wire from the factory, but the new ECU is looking for a 3-wire setup (which I have). Do I need a Y8 throttle body and 3 to 2-wire IACV swap (BOTH those are in there, spliced to each other) so I can run whichever I need. It was a stupid frustrating day and now I'm convinced that I've got a wire to move on the ECU pinouts and/or something to change on the IACV itself (ableit using the FFSQUAD write-up or just tracing the wires to find which ISN'T wired into anything). Either way I know that that's the issue because it's doing exactly what people have said it'll do if you don't do the IACV fix. Final question is should it be running a 3-wire IACV for the P2P ECU? Since mine is already 3-wire, do I just find the unused one and wire to pinout A12? Do I need a Y8 throttle body to make this "simpler" and be a smooth fix? I'm potentially 1 wire away fromt VTEC.
I apologize if that is uncomprehensible. We fought and tweaked all day to get it right and at the end of the night I popped in my stock ECU and drove home VTECless.
