This is a typical aftermarket steering wheel horn problem. I've been searching like crazy and found some solutions, but I don't quite understand them (like the whole soldering wires to the copper piece and s**t like that).
Anyway, I already have a switch (button) for my horn and it works. I just don't like it and I want the horn button to be on the steering wheel.
Here's the switch...
2 wires come from it. One ground. One wire that goes into a harness (guessing to the horn)
Here's where the one wire goes (into a harness)
I know it's blurry. Sorry. But its just a clip with a bunch of wires that come from a harness. I'm guessing it's another route to the horn instead of going through the SRS (?)
Here is the SRS Harness (the harness that connected to the swivel that went into the oem wheel)
Here's the white wire that comes out of the hub (if I recall I think this comes with the hub and it's soldered to the back of the hub from the inside)
And finally: This is the back of the aftermarket horn button. Two slots; one for ground and one for the harness (im guessing)
Here's my question:
Since I already have a wire going into a harness that makes the horn go beep; is there a way I can just run that wire through the hub (or something like that) and connect to the back of the horn button?
Problems: Back of hub has no openings AND steering wheels turn...therefore that's why they have that oem swivel thingy (SRS)
Hope this gets answered. Maybe when it does it will help a ton of people out. I don't have a solder gun so if I have to do the copper thing I'm kinda screwed.
Please Help!!!!
Here's my question:
Please Help!!!!
