most likely code 88
Code 0 ECU ECU bad, or ECU fuse blown Check ECU Fuse, Check Eeprom is in socket correctly and not loose
Code 1 Oxygen Sensor Loose Wiring, Bad Sensor If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 3 and 5 Map Sensor Wiring, Bad Sensor Make sure sensor is plugged in and wiring is correct
Code 4 CKP (crankshaft position sensor) Loose Wiring Check that distributor plugs are connected and wiring is not loose
Code 6 Coolant Temperature Loose Wiring, Bad Sensor Check that plug is connected and wiring is not loose
Code 7 TPS (throttle position sensor) Loose Wiring, Bad Sensor Make sure sensor is plugged in and wiring is correct
Code 8 TDC Position (Top Dead Center) Loose Wiring Check that distributor plugs are connected and wiring is not loose
Code 9 No.1 Cylinder Position (CYP) Loose Wiring Check that distributor plugs are connected and wiring is not loose
Code 10 Intake Air Temperature (IAT) Incorrect harness plug, Bad Sensor Check that correct sensor plug is connected, Replace Sensor
Code 12 Exhaust Gas Recirculation Incorrect harness plug, Bad Sensor If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 13 Barometric Pressure Bad Sensor If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 14 Idle Air Control Valve (IACV) Incorrect harness plug, Bad Sensor Check that correct sensor plug is connected, Replace Sensor
Code 15 Ignition Output Signal Loose Wiring, Bad Sensor Check wiring, most likely wiring will be the issue
Code 16 Fuel Injector Loose Wiring Check wiring, most likely wiring will be the issue
Code 17 Vehicle Speed Sensor Loose Wiring, Bad Sensor Check that plug is connected and wiring is not loose
Code 19 Lock-up Control Solenoid Loose Wiring, Bad Sensor If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 20 Electronic Load Detector (ELD) Loose Wiring, Bad Sensor If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 21 Vtec Solenoid Loose Wiring, Bad Sensor This is common, make wire is ran to correct ecu pin location (pin D14)
Code 22 Vtec Pressure Switch Loose Wiring, No oil pressure If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 23 Knock Sensor Loose Wiring, Bad Sensor If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 41 and 48 Oxygen Sensor Heater Circuit Loose Wiring, Bad Sensor If getting tuning done, don’t worry about this code its not vital and will be disabled
Code 43 Fuel System Supply Low fuel pressure, vacuum leaks Make sure fuel pressure is adequate at idle (40-50psi base), check for vacuum leaks
Code 88 Flux Capacitor Not Engaging, most likely lack of plutonium which is needed to create the 1.21 jiggawatts of electricity that will activate the time travel process. Can also use a lightning rod and hope for a bolt of lightning bolt to strike your vehicle while traveling 88mph
