egincivic97
Car type : Honda Civic '97 Sedan Automatic
Recently sent the car for inspection in a Honda Service Center because local repair guys refuse to touch the problem (engine oil leaks primarily)...Said it's too complicated and sensitive for them :-)
Anyway, below is a summary of the findings...I'm typing this as per what the paper show
Surprised to discover some other problems though :-D
KIndly enlighten me if you have the time to explain...thanks in advance !!!
for ENGINE OIL LEAKS :
Head cover packing set
Parts cleaner
Distributor ring
Cam Shaft Oil leak
Timing belt
Tensioner bearing
for POWER STEERING CONCERN :
Gear box reman
Overhaul Vane pump
Steering suction hose
Return hose
Oil tank hose
Joint return hose
PSF
Parts cleaner
for ATF LEAK CONCERN (they put urgent)
Shifting solenoid
Drive Shaft oil seal left
Drive Shaft oil seal right
Shifting rod oil seal
Rear crank shaft oil seal
Input shaft oil seal
ATF flushing
*COOLING SYSTEM EVALUATION AFTER CORRECTION OF ENGINE OIL LEAKS *
All of these for approx. $ 1,150 (converted from Phil. Peso)
Engine oil leaks done, my priority, 1 day job
The rest of the list i have to see
Am i in deep trouble ?
Parts cleaner
Distributor ring
Cam Shaft Oil leak
Timing belt
Tensioner bearing
Gear box reman
Overhaul Vane pump
Return hose
Oil tank hose
Joint return hose
PSF
Parts cleaner
Shifting solenoid
ATF flushing
