Short Write up for 06-08 si rear seats in 96-00
3Z CIVIC
1.first thing to do is take out the whole rear seats
2.then you have to take a part the top part of the rear seats ( reason you are doing this is because you be needing the 2 seat pane without the seat foam and cover)
3.you have to cut some metal clips to take off the seat cover
4.after you have remove the rear top part of the seat cover its now time to remove the seat foam( after this process all you should have left is the 2 metal seat panel with out foam and cover)
5. now this step is easy all you have to do is take out the seat panel from the 06-08 si seats (all you do is left back cover with hands then easy remove foam and cover with your hands and dont forget to take out the head rest !!!!!!!!!!!!!!!!!!There is No Cutting needed for this step!!!!!!!!!!)
6.now all you do is put the foam with the cover (that came from the 06-08 si seats) and put it on your stock seat panels ( you just have to adjust it a little bet and use some zip ties and your done)
7.now all you have to do is bolt them back on and your done with the top part it should look like this
now for the bottoms parts
8.have your 06-08 si seats bottom part it shoud look like this
9.this part you would need something to cut something strong for metal ...You have to cut off as much as you can of the 2 metal hooks when your done they should look like this
when done cutting this is how it should look
10. now all you do is pop them in and your done
after your all done this is how it looks
well thanks for looking (now pls bare with me this not a great write up but its a simple one )
happy answer any ?
idkfreddy
Saw your posts on craigslist
nice write up!
3Z CIVIC
lol you did i got three sets of them i just traded it for a bike rack and some school books but thanks
