Should I buy: Integra GSR leather seats
genzopwns
someone's selling a set (front and rear) of grey gsr leather seats from a sedan and was wondering if I should buy it for my 98 civic ex sedan to swap out the seats. I researched it a bit before contacting the seller and most have said that one bolt will not fit on the rail of the driver's side. another mentioned that he swapped out the rails on the seats on the fronts.
basically wondering how much work I need to do to swap out the seats before I go through with it since it's not exactly as easy as bolting it on. and can anyone find me a thorough write up? most i've seen is just a quick summary of what they did.
cgpEJ6
noob
I have the exact same set up. The fronts are very easy to put in, you just swap out the inner rail (closest to the console) with the one from your Civic. It's like 10-15 minutes per seat, just a few bolts. The rear seats fit pretty well but do leave a small gap on the outside, you can't see it with the door closed but when the door is open there is about an inch gap.
