Side markers
Katayst Tuning
Does anyone know a wiring diagram for doing the side markers? i know it is pretty simple..cuase there is only a black and white coming from the side marker...thanks
00CivicGirl
black - ground
white - hot
jsut secure the black to the chassis and the white splice it into whatever you want to run the sidemarkers, example
toggle - if you want to be able to turn it on and off whenever you want
headlight switch - if you want em to turn on when you turn your lights on
turn signal - if you want em to turn on when you put on your turn signal.
illusive
She is right, easy way is just run the wire though your fender to your corner light and tap your wires from there
Jas0n
What's up dogz!!!
Originally posted by 00CivicGirl
black - ground
white - hot
exactly
