Slammed Suspension
DookieLSC
Planning on slamming (lowering) my 98 DX Sedan. Just wanted to know what some good/fair priced coilovers would be. I heard Racelands are reasonable but would like more opinions. Also any other advice on lowering the car would be appreciated. Thanks..
EJwood
Remember that coil overs are your main suspension components but you're probably also going to want to invest in some rear/front camber kits to prevent uneaven tire wear.
CHILD
All Day, All JDM
http://marketplace.honda-tech.com/sh....php?t=2967499
there is no information there regarding "slammed suspension"
to the OP, you will need more than just a set of coilovers (or shock and coil sleeve) setup to have a properly slammed ride. Simply dropping the car as low as you can, can lead to several other issues.
EJwood, camber does affect tire wear, but not nearly as much as having out of spec toe angles. Get the car aligned. The amount of camber will depend on the wheel and tire setup as well as ride height.
RealRabbit
Agree completely but it will still cause wear for an unnecessary reason. Also it will greatly affect handling depending on how much negative he has. Bump steer....
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
DMaldonado93
hah i like how u put it lowering in parentheses just in case somebody didnt know! But I may get b####ed at for this but look into megan racing coil overs. Ive never personally had them but ive seen a lot of good reviews for them
CHILD
All Day, All JDM
thats not really that low. His wheel and tire setup fills the gap pretty well though. Im sure everyone would suggest going with a good reputable coilover/shock coil sleeve setup, alignment, and camber kit if needed. There are plenty of different combos that can get you there...some cheap, some not, some long lasting, some short.
just like an engine swap, its going to come down to budget. Try to get the most for your dollar, rather than the overall cheapest, so that you won't have to revisit your suspension in the future.
if you were going lower than that, you'd need a bit of custom work to get the car to function well at a very low height.
mymmeryloss
RHD is where its at
Well since its going to be my daily I don't plan on pebble pushing.
http://www.stancenation.com/2011/07/16/hafa-adai-world/
That's basically what I have in mind..
As much as we?re all about pushing the envelope and doing things no one has done before, we can also appreciate the simpler things in life. Jason?s 1999 Honda Civic would be just the right example. He wanted a reliable car that sat right, and this is what he came up with. A clean Civic Sedan that he is able to use as his daily back in Guam. It?s dropped on Apexi N1 EXV coilovers and is sitting on set of ESM 002 wheels. They are 16×9 (+20) with 205/40 tires all around. Less is more, remember?
Read the article and it tells u exactly what coilover setup he is running.... If thats the look u want, then get what hes got...
Sent from my Butthole using Fart power!
6thGenFtw
koni/ground control is all you need
EDIT: and i would not recommend daily driving hellaflush or stanced tryed it for 3 months and it sucks balls but thats just my .02
CHILD
All Day, All JDM
I drive flush everyday....no issues. :what: the people who do it and their s**t rubs and scrapes is doing it wrong. It should look like it can't be driven rather than not actually being able to drive.
