stince
So guys.. i was about to sell my gt28r turbo kit and go deuce deuce.
i decided instead of spending 3500 on a h22 swap...
i'm completely rebuilding my D16.
yes.. i'm staying sohc..
but here are the parts and so on to be hitting the car next week. (on my D16y7)
Engine//Turbo//Suspension
Block is going to be Hone'd
Block is going to be bored over .20
Block is getting acid dropped // Jet Sprayed
Block is getting new silver spray
Head is getting ported and polished
Head is getting Heat tanked
JGE SRP Pistons 9:1
Eagle H-Beams
Ferrea Valves and Retainers
Crower Stage 2 Turbo Cam
ARP Rod Bolts
ARP HeadStuds
New Headgasket
Tuner Toys GT Oil Lines
Tuner Toys Water Coolant Lines
Walhbro Pump
Oil Pan Gasket
Oil Screen Gasket
Intake Manifold Gasket
Exhaust Manifold Gasket
Rear Main Seal
Front Main Seal
Valve Cover Gasket Set
NGK iridium spark plugs
ACT Streetlight 11lb Flywheel
Tokico Blues with Ground Control coilovers
AEM Big Brake Kit
Si Gauge Cluster
New Y8 Head
Y8 Intake Manifold
P28 (turbo basemap until tuned on crome by John Kerr of www.j-k-tuning.com)
OBD2a>1
Custom Made Manifold
Custom Downpipe with vband Ftw.
DSM 450 Bluetops
TurboSmart BOV
Turbo XS Front Mount
Custom Made 3" Charge piping
Custom Oil Lines
AutoMeter Pro Comp Ultra Lite Seires Boost/Vac gauge
AutoMeter Pro Comp Ultra Lite Series Oil Pressure Gauge
Exterior
Lips Color Matched
New Dunlop Street slicks
Custom Paint Job Touch Up
Retro Fit BMW Projectors
if i'm forgetting anything else.. i will update.
Looking to run 12lbs and put down high 200's at the wheels..
then get a 3bar map sensor and 550rc's and run 18lbs and aim at high 300's
JGE SRP Pistons 9:1
Eagle H-Beams
ARP Rod Bolts
ARP HeadStuds
New Headgasket
Walhbro Pump
Oil Pan Gasket
Oil Screen Gasket
Rear Main Seal
Front Main Seal
AEM Big Brake Kit
Si Gauge Cluster
New Y8 Head
Y8 Intake Manifold
OBD2a>1
DSM 450 Bluetops
TurboSmart BOV
Custom Oil Lines
Exterior
Lips Color Matched
