well my car isnt stock. i have a 95 d15b vtec mated with y8 intake mani and exhaust header with a 12 lb flywheel and pretty much all bolt ons and tuned ecu. I can reach 80 in a really short 3rd gear pull.Why are you down shifting into 2nd from 4th? There is no set RPM and you are going to have to rev pretty high if you are skipping gears like that. There is no need to downshift that far. Take it one gear at a time.
Think about it like this...what rpm is the motor at if you take 2nd gear all the way to 40mph? If you can even get that fast in 2nd gear that would be the rpm you would need to match if down shifting into that gear at that speed.
Lol. Yeah that's not saying much man, no offense.well my car isnt stock. i have a 95 d15b vtec mated with y8 intake mani and exhaust header with a 12 lb flywheel and pretty much all bolt ons and tuned ecu. I can reach 80 in a really short 3rd gear pull.
none of that has to do with the gearing of the transmission....well my car isnt stock. i have a 95 d15b vtec mated with y8 intake mani and exhaust header with a 12 lb flywheel and pretty much all bolt ons and tuned ecu. I can reach 80 in a really short 3rd gear pull.
Essentially, downshift one gear below what you're at. Nothing more. If you go from 4th to 2nd, you're likely going to cause more damage than good.
x2 to both of these.none of that has to do with the gearing of the transmission....
I must need a new exhaust with headers cuz i rev high at 4-5rpm's like im at redline or somthing.so 2nd goes to 40mph or 65 if i hold it out to 5 rpm but then it sounds like its close to redlining.maybe exhaust or manifold or somthing.its a y7 but hell it can pick up fast if you need it to.plus i gotta cracked exhaust mani maybe that plays a roll.
Sent from my SGH-T679 using Tapatalk 2
Hahaha OG, Imagine driving your GSR daily all the time you have a decent ammount of power etc. Went from my boosted gsr to a d15b7 with long ass gears daily. I swear i'm either wide open throttle or 0 throttle. It's the only way to gain speed.. Lmfao.A friend just bought a Civic with the wrong gearbox and he can do like 80+ in 2nd gear. I don't think the car has seen 4th gear since he's had it
wtfI must need a new exhaust with headers cuz i rev high at 4-5rpm's like im at redline or somthing.so 2nd goes to 40mph or 65 if i hold it out to 5 rpm but then it sounds like its close to redlining.maybe exhaust or manifold or somthing.its a y7 but hell it can pick up fast if you need it to.plus i gotta cracked exhaust mani maybe that plays a roll.
