Something may be wrong...
lanojp1
I may be wrong, but it seems that my VTEC is not engaging. i have a d16y8vtec and doesnt it engage at around 5500 rpms? I dont seem to notice any difference... could it be my ecu has disengaged it due to other problems?
Mahlmann
close the windows and turn the radio off... accelerate in 2nd and 3rd and listen real carefully, the engine tone should change and if you have an intake you'll hear air getting sucked in. also is your check engine light on? make sure your car is warmed up enough. check the oil level also.
2kstreetcivic
Runnin to Redline
did you check the vtec fluid???.....:hithead: :hithead:
...okay seriously, do you have and mods, are you getting any codes flashed at you?
Rick James
turn everything down and punch the s**t as hard as u can.
daniel (seanjohn1802) has a vid of his car hittting vtec
StreetEuro99
Dont make me reload!
Check your oil level, vtec is also oil preasure sensitive, if you dont have enough oil, you dont get vtec, happened to me once, was about half a quart low, scared the s**t out of me, thought i busted something. Started callin friends, one said to check the oil, i put half a quart in, and there it was.
Mustangb12
when the vtec engages, it should sound like a grinding sound. it can be hard to hear, so do as everyone else has said and just keep the cabin quiet
lanojp1
hmm...just got my oil changed and some other maitnence...
my check engine light was on a while ago, but got that fixed...
im gunna punch it in 2nd and 3rd tonight i guess and see if i can hear it, it shouldnt be a problem cuz my cd player broke..
shinobi
i never heard of vtec making a grinding sound.
M706
somethingmorethannothing
is vtec actually that noticeable in a y8?
anekin007
Unregistered User
on a stock sohc, vtec is not really noticeable. the only way you can tell if vtec is not working is when you go pass your vtec crossover point and make it go up to redline, if you dont feel your car pulling then something is wrong and vtec is not engaging. if your at 6k rpm and you feel power droping then, most likely vtec is not engaging.
Mahlmann
i have a d16y8 and i notice it w/ an intake, not as much as a dohc, but it's still there
lanojp1
yea im not noticing it, i tried like 5 times yesterday..
