^^^We need a lot more details before we can help you with your diagnosis. Have you checked your firing order? Fuel pressure? Any other abnormal symptoms? Do you have any cell codes (check engine) ?What did you do to it???!!!!
Seriously. Did it just start doing that? Or did you change something / buy it like that? I'd say check the firing order, but we need more details.
First things first, get an OBD2 port scanner (you can usually rent them from an automotive store), and get the code number and description of the CEL that it's giving you. That will give you a good place to start your repairs. Glad to hear it's running, but sounds like you've got a bit of work ahead of you.The car was given to me and all i have to do is repair it. The only thing i did was replace the crank sensor and replace the distributor completely on the car.
Sense my last post the car starts, but now it idles roughly and backfires and the engine did occasionally go up on the rpms when i press on the accelerator. Most of the time no matter how far i push the peddle it mostly stays at a rough idle and when it does idle up the motor tries to idle up but goes back down and tries to stop running. I did note that the engine light is on now because before it did not come on at all.
