Speedo Needle Died
Silver Bullet
6 spd = titis
well ive been driving around for weeks without knowing how fast im going i went to autozone to see what they said and it was my speed sensor..so i replace the sensor at least 4 times still nothing
the needle moved once in awhile but now it just stopped every other needle works and my car usually redlines at 7 and also shifts at 7000 rpm when i floor it but now it redlines at 6k when i floor it and it doesnt even go into the next gear...(automatic) so in order for it to shift i have to let go of the gas :oops:
heres a quick vid...i disconnected the battery to erase the check engine light but it turned on again
http://s63.photobucket.com/albums/h152/lonerone/?action=view&current=Picture031.flv
im lookin for a new cluster to see if thats the problem
hooked_on4
RegularFlush
i have a similar thing w/mine, speedo needle goes on and off periodically, I'm thinkin it's a loose wire somewhere. You replace the VSS? Was that hard?
whtcivic93
www.mm-graphics.net
I already told you my thoughts... swap the cluster out and see if that does it.
Silver Bullet
6 spd = titis
switched the VSS 4 times....its easy that wasnt the problem tho...trying to find a cluster tho
hooked_on4
RegularFlush
did it improve at all with any of the switches? Did it work fine right afterwards then go out again?
hooked_on4
RegularFlush
Every try banging on the dashboard to see if it flips back on momentarily? I tried didn't do anything, worth a shot lol
Genuine Rolla
Its PETEY PETE, y0!
Hit up a local junkyard if you can, I really think its the cluster.
Zaiber
My car does the same thing...except look at the wieird part. The speedo only works when it rains...I have no idea why. I think it has something to do with a bad connection somewhere and humdity gets it to make a good connection, cause this sounds so weird.
