Speedometer doesnt work on a 1996 Honda Civic HX
kairuriak
I have replaced the connector to the VSS, the actual VSS, and the IPC and still have no results. Does anyone have any Ideas?
I'm almost positive it's a wiring issue, how exactly would I rewire it?
taluzer45
4 Banger Deluxe
Try the cluster it's self!
kairuriak
Really? absolutely no one knows? Am I just better off buying a completely different car or what?
gugiey
at this point it's hard for anyone to help you . it's most likely a wiring issue .
to rewire it you would have to get a wiring diagram and just run new wires .
I've heard hondas are bad for the wiring rubbing on a bracket . I would start by tracing your wires make sure there not rubbing on anything .
also I'f you know a little bit about electrical you can see I'f the sensor is getting power and a good ground .
