CoyoteBlack
I spun a rod bearing up from low oil, no real doubt on that d16y7 built block and z6 heads. My pistons and block itself should be fine. I knew right when it happened and killed the power.
Should be a crank and rod replacement then correct?
Here are my questions:
1. Check my attachments, what crank/ rods where should I get it
2. I need to pull the whole engine for this correct?
3. What else am I missing on this, I feel like it can't possibly be as "plug and play" as it seems.
