Sputtering
dis_jaydeem_ej2
ok guys, I have a b16a2 mid built and my car just recently sputtering really bad. I change the motor oil, did a basic tune up, change fuel pump, fuel injectors, iacv, map sensor, check my timing n it is TDC, check my compression and it passes. With all tat was done, it still sputtering. What can it be? For got to mention, on my forth spark plug seem to have no spark.
Car? ECU? Mods?
No spark = no run
dis_jaydeem_ej2
99 honda civic hb
this is what I done to the motor:
engine: b16a2
Head:
skunk 2 pro 1 camshaft
aem adjustable cam gear
port and polish head
super tech dual valve springs
super tech flat surface valves
super tech valve guide
Power performance intake manifold and TB
toda racing header
brand new honda water and oil pumps
new alternator
new starter
brand new iacv
brand new 3 bar map sensor
brand new fuel injector
brand new walbro 255 fuel pump
Block:
civic type R piston
honda piston ring kit
acl racing bearing
micro polish crankshaft and balance
rods are stock but micro polish and balance
honda head gaskets
block is resurface and homb
ecu:
chipped p78
there is spark but just not on the forth spark plug.
lethal6
Your Mom's Moderator
Need to fix why the 4th spark plug isn't getting spark. THAT is your stuttering problem. You are only running off 3 cylinders.
dis_jaydeem_ej2
I did open up the distributor and everything seem fine. I ma try to swap out the ecu and see if it makes any different. I will probably pull out my friend working distributor and see if any of these will fix my problem.
