Juanito8
I have a 98 Civic Hatchback Dx with a Gsr head and B18B block. I need help finding out why my car won't start. It currently does not crank. The owner I bought this from had removed the clutch safety switch and put a cut in the wires right before the connector so he could start it without pushing the clutch in.
It ran fine until one day I knocked those wires loose. I was able to twist them and make them touch each other a handful of times... Not smart I know. Well the last time I attempted to start the car, it cranked and then finally nothing. The engine will not turn over. It's a brand new battery.
All of my accessories work
I have tried a new main relay and new starter just see if they were bad but still nothing.
There is no voltage at Fuse 31: Starter Signal Fuse, nor the terminal it goes in
My grounds at the battery are good
I have an aftermarket alarm if it makes any difference. I don't have a wiring diagram.
All I have is a test light to work with. I am all out ideas, can anyone please please help
