trafficlightguy
I see you know a lot about civics, I currently rebuilt my sons d16y8 after blowing #4 rod threw the oil pan
I got a short block honed and replace with new pistons , I also did the oil pump mod , but not the shim on the pressure spring
I reinstalled the motor, getting spark but no spark timing set perfect
But is had placed the ground that went to the water neck on the transmission ground would that be a problem , plus it was really super tight , I felt that there was movement in the ground connection.
Iam currently pulling the motor back out cause there something I don't like the way the harness runs behind the intake
Sorry for the emal
Thanks for the info
Sorry for the emal
Thanks for the info
