This morning, when i got out to start my car it would not start.
When i turned the ignition key, the check engine light came on, and the engine/starter was not cranking.
(The lights in the dash and everything else electrical worked as normal)
So i tried to turn the ignition-key a few more times, and after 2-3 minutes of trying the car suddenly started as normal. I stopped the car and tried starting it up straight away, and this time everything worked as normal.
Now, forgive me for not listening for sounds like relay-clicks or fuelpump-sound, but I was stressed and in a hurry to get to work.
It has to be said that it was below freezing temperatures outside (if that makes a difference), although it was freezing yesterday aswell and then I had no problems.
My first thought is just a worn relay (starter-relay or something like that), but its not easy to assess with what seems a sporadic problem.
I tried searching the forums with no luck, so i was hoping you could help me out.
