Steering Wheel Shakes
defvayne
Set This World On Blaze!!
Ok im having a problem with my car.. it seems when im going more than 50mph and i stop to brake. The steering wheel starts to shake really bad. Would it be the lower control arm or the brakes but it shakes on the left driver side. Any help will do?
codyj86
sounds like brakes to me
Justyntyme
5th gen civics are it.
My guess would be your rotor is grooved. Take off your tire and rub your hands on the front and back of the rotor and make sure it is perfectly smooth. Good luck.
Tkdcobra
i had the same problem with my 92 civic. my problem was the rims though. my rims had been cracked and welded back together b4 i bought the car. u might want to check out ur rims to see if that may be the problem.
defvayne
i know its not the rim cause i had bought a new steely for my car when i hit a hole and it broke. Someone said it might be the control arm or something like that because when i turn left the left side starts to pop.
kellog
my brother just had this problem in his car cept it was under warrenty. his rotors were waprted and some minor axle problems.
defvayne
ok i checked it out and its the control arm and the brakes. thank guys.
elgs
Maybe your tires are unbalanced, and you need to balance your tires.
JCV2000
Dirty South Side
Yeah, i bet your control arm could be messed up if you nailed a pothole hard enough to brake a rim.
defvayne
yeah i checked it out and i found out its the whole axle. ima get my tires balanced to see if i can get them running smooth and get new brake rotors and pads
munky
i need to check this out on mine.. i was kinda thinking it might have something to do with my ABS.. thx guys!
skinnyjdm
Always bet on black
I have slotted rotors and it does the same thing but only under heavy braking
