you can still keep everything, buy the Metra harnes 80-1720T, it allow you to keep the stock radio in there, you just have to keep it down inside behing everything. If not, you cut the black/green and the red/green and tag them together so that the dome light still tunrs on atleastTek-C said:say goodbye to your Keyless entry and dome light...
The keyless enrty is in the radio. Why honda didi it like that , I have no ide. But usually when you swap out for a new radio, your keyless usually goes with it, unless you use the 1720T harness. nad you usually have to cut those 2 wires I mentioned on the green plug to keep the dome light when you open that door.rexxxgirl said:my dome light still works....whats that supposed to mean? and I don't have keyless entry...
sounds splended , then all that's left is to rock the tunesrexxxgirl said:nah I didn't cut any wires and my dome light still works when I open my door.
yeah, i didn't waste my money on the harness...just spliced the power and ground wires...JDMk20A2 said:you can still keep everything, buy the Metra harnes 80-1720T, it allow you to keep the stock radio in there, you just have to keep it down inside behing everything. If not, you cut the black/green and the red/green and tag them together so that the dome light still tunrs on atleast
