stuck with 10.5:1 pistons
jason_guy_yeah
For my eventual turboed b18b, I already have eagle beams and pistons. My WHP goal is 400 but, how do I turbo size right with high cp?
jason_guy_yeah
With 9:1 cp pistons, I would use a say...T61. But, with 10.5:1 cp pistons, what size turbo do I use?
bump
MrRide2Low
no turbo, size doesn't matter to your compression, 10.5:1 is to much for boost, sure i can work but it's not that safe, i'm not saying you can't do it but you will have alot of knock, we boosted a jdm gsr at 10.6:1 and end endresults were 2 holes in the block, didn't make it even 2 hours before it boost spiked and rapidly dissasembled it's self on the road to the dyno. in other word's just bit the bullet and drop your compression ratio with some different pistons or you prolly won't like the small amount of boosty that your kinda limited to
Kaotic_Zeus
Most hated man
i would never recomend boosting anything with 10:5:1 or higher CR, unless you lower it.
Steven.
Formally Green 91
sell the 10.5:1 pistons for lower ones
jason_guy_yeah
Although I've got high CP, I need help turbo sizing. So far I've found that a GT4038 or T61 works (b18a)but, would I lower the displacement factor?
Steven.
Formally Green 91
damn, those are big turbos, whats this for? street? drag? those are really big for 400hp, a GT30 should be suffciant
jason_guy_yeah
Steven.
Formally Green 91
i recommend go buy teh book "maximum Boost" by corky bell.
that will help you in sizing the turbo.
schutzracing
#1 ricer
boost it and see what happens.. o tape it soo we can watch.. maybe it will work out good on low boost.. who knows..
jason_guy_yeah
On low boost I know it'll be alright, It's finding the right turbo and the 400whp goal is the problem. But, I'll tape the dyno...when I get there eventualy (months from now).
majorahole
mr. gasket has layer-able gaskets to lower compression. check out those.
you can boost it with the 10.5, but you need to have a perfect tune. even then its iffy
juan2k2001
10,5.1 is not bad just build right get it balanced to perfect spec...good oil pump...ACL bearings and a good tune and you be good..My boy LS did 545whp with the same thing..Just sleeved..545whp aint no game....
Blazed
f**k The Powers That B
10.5 is not that high a compression..just get a good tuner..
and even if u have to go with a smaller turbo which is just not true..u will make more power on less psi with higher comp than u woudl with lower comp...
