sub cutting out not eough juice???
BRAK54
come getcha some
Hi i have a older verison type R 12in is sub and a jvc 580wt amp and the sub always cuts out when the bass comes in then u will hear the bass come back in slowly like its suckin all the poser then it starts to rebuild the power hit a bass note then cut out again
someone help i no the amp and push it someone told me it mite be the wiring
if anyone has pics of there amp hooked up to there sub send them plz
ridin4jesus
is the jvc a mono or 2 channel, ive never heard of a sub just cutting out, how do you have it wired? can you post a pic? have you ever been out at night and it done this, cause if it was the battery the lights would have dimmed and your eletrical stuff would have dimmed. does the sub cut out or the amp cut out?
DFlannery
Is it just the subwoofer cutting out? Does the amplifer go into a protect state? It may be a problem with the headunit. Possibly a bad connection on the PCB or a circuit protection.
Genuine Rolla
Its PETEY PETE, y0!
Does this only happen when the volume is high..?
If it is, its called clipping. all you gotta do is turn down the volume h0mie.
kaace
I'm getting there...
first things first...reground the amp...check the power connections at the battery...check power and ground before you check anything else...
ridin4jesus
also check to what gauge the wire is,
and the worst thing people can do to there subs is have that little button on the head unit called "loud" on, that crappy button wears on the sub and doesnt really make it sound any better
