Sub Enclosure
andres4514
PaRsEro
i got a 700 watt amp and a 1000 watt sub.....the prob is i dont think im getting enough base....what might be the problem...mayb its the enclosure bcuz is kinda falling apart....or maybe is the connections......wut might be the problem....if its the enclosure then wut box would you recommend me to get...thankx in advance
Jezek
No Avatar FTW.
is it a ported box?
1999stockaccord
Honduh's... LULZ
pics would help, and a better description
CRX_dude
copyright 2006 omgwtflol
if your box is falling apart the get another one.... i would get a good strong well made sealed enclosure.
bolisticSI
look under the hood first
I would need to know what kind of sub and amp you have. Also what deck you have and your size of hot wire, ground and speaker wire.
andres4514
PaRsEro
alrigh i have a 700 watt alpine amp.....1000watt 10" MTX sub....i have a sony Xplod deck cdx-L510x 50wx4.....the hotwire is pretty long and i think is supposed to hold 200 watts
bolisticSI
By size of wire I mean what guage of wire is it. Another thing is 10" subs hit high bass and not so much low or deep bass. Is the MTX sub a 9500 series? Now the most important thing with a system is your box. The box will make a world of difference. You need to check your paperwork on your sub and see what the recommened air space for a sub enclosure is. I build allways build my own boxes. Boxes bought from a manufacturer is not made for your sub, they are just made for looks or money. Your MTX book shoud tell you the dimensions of a sealed box and a jetted or ported box. It will also tell you the cubic feet of air space it needs if you want to build a custom box that isn't a perfect square. By my guess is it is your box. I guarentee with the recommened box dimensions and air space it will make a huge difference. Hope this helps let me know.
that VERBAL
AKA Theiven Stealberg
yeah, it sounds like the box to me. I agree with bolistic, you should build your own box. The recommended cubic footage for your sub is readily available online if you have the product number.
