EG-Owns you said:
yup good call dont need a cap mmmm hmmm and my amp was a f**king MM 2000.1D so good call on that one again
Unless you had a upgraded alternator a cap didn't do s**t in your car. A cap can not re write ohms law and your alternator could not supprt a 2000 watt amp unless it was wound to about a 300 amp alternator.
Caps do pretty much nothing unless you first upgrade your alternator for larger systems.
And if you have small wire, the fix for that is to put the proper wire on the amp. Using a cap to fix that is just plain ghetto.
So in your own words good call on that one
and replacing the big three will give you a solid voltage flow. Keep everything the same gauge and you are set.
Good call chaos
