Subframe question
Oem>
Got in an accident a while back, hit a curb, and my wheel got bent it. Replaced the lca because it looked like a V. After sometime i noticed that tire was wearing out way quicker than the other side and was rubbing against the wheel well. Went to a Shop and they said 150 to put it on the frame puller and try to get it straight. It rubs and looks - cambered. Is the 150 a good price? Could there be another possibility for the wheel being that way?
97 Civic dx if it matters
gugiey
with out seeing it our selfs it's hard to tell you bro .
I'f your tire is in a different location then the other side then there's
probably Something else bent.
have you observed the knuckle , the strut and strut tower for damage ?
did you perform an alignment after replacing the damaged parts ?I'f so
it does not sound like a alignment problem .
and 150 is good .
Oem>
ill post a pic, im sort of a noob so maybe im missing something but to me everything visually looks straight.
I replaced the whole knuckle and strut with one from a junkyard, friend of mine checked it out and said everything looked straight on the donor civic. Went to get an alignment and they said the numbers were off for the wheel
mymmeryloss
RHD is where its at
$150 sounds good to me...
Sent from my Butthole using Fart power!
