super chargers make everything slower, and f**k that honda engine
200 hp with intake s**t i should sell my civic
btw stock sunfre numbers:
995 — 2.3 L (138 cu in) Quad 4(RPO: LD2) I4, 150 hp (116 kW) and 150 lb·ft (203 N·m)
1995–1997 — 2.2 L (134 cu in) 2200 I4, 120 hp (89 kW) and 130 lb·ft (176 N·m)
1998–2002 — 2.2 L (134 cu in) 2200 I4, 115 hp (86 kW) and 135 lb·ft (183 N·m)
1996–2002 — 2.4 L (146 cu in) Twin Cam (RPO: LD9) I4, 150 hp (112 kW) and 155 lb·ft (210 N·m)
2003–2006 — 2.2 L (134 cu in) Ecotec I4, 140 hp (104 kW) and 150 lb·ft (203 N·m)
The base model had the 2.2 L engine from 1995 until 2002. The GT trim level had an optional, much more powerful 2.3 L Quad 4 engine in 1995, which was replaced by the 2.4 L LD9 engine in 1996. The 2.3 and 2.4 liter engines were optional in the 2 and 4 door SE trim level. In 2003, both the 2.2 L and the 2.4 L engines were replaced by the 2.2 L Ecotec engine, and would be the only powertrain available for the remained of production. The Ecotec engine was also an option for the 2002 model year.[5]
