sunroof switch repair
MiniMeRatrod
If this has been covered a million times just delete this. i couldnt find it myself
Sunroof would shut with power but wouldnt open, found the switch was bad, the switch itself comes apart Very straight forward.
I found a burn on the green panel that cut off the power to the down button, i soldered my wire to the board past the burn, drilled a hole threw the board, ran the wire threw and soldered it to where the pin was soldered, works perfect now.
Only trouble was when u pop the buttons off the board it will fall apart with 3 springs 3 ball bearings, and 3 pins all held in with gravity
