drix
Hello everyone ! Im Darek. I have Civic EJ2 LSi about 5 years. Now I swaped engine from D15B7 to D16Y8 and I have problem with start the engine...
What I did:
What I checked:
I will be grateful if someone tell me what I should check.
Greetings !
What I did:
- ECU P06 modiffication: added VTEC and chip with injection map from D16Y8
- engine harness OBD1 from D15B7 with added wire to VTEC control (pin A4 in ECU)
- Inhaust and Exhaust manifold from D16Z6
- distributor TD41U (OBD1, D15B7)
- spark plug cables D16Y8
- engine block and head D16Y8
What I checked:
- engine timing gear is set properly
- fuel on the spark plug - is
- spark on the spark plug - is . I checked it on all the spark plug cables
- ECU in service mode doesnt report errors
Greetings !
