Hi, I need help! I have a 93 Civic DX that *had* a d15b7 with 190,000+ miles on it and was burning a ton of oil. I was looking at rebuilding that engine or swapping. For better or worse, I went swap with a jdm d15b vtec, mugen p28 obd1 ecu and si vtec engine harness from a d16z6. I'm sure some of you are lol or shaking your heads. It runs. I get 3 mpg and a constant pulsing idle. I'm thinking its in the wiring, but where? Although I was told my original engine harness would work, it was short three plugs for the vtec, which is why the si vtec harness. There is also a plug on the si engine harness that I can't find a place for on the d15b. I still have the original obd1 ecu harness hooked up to the engine harness. Is there info on the match up of p28 ecu pinouts to engine harness? And, is there anything else I've overlooked on this swap?
