swapping y7 to b18 ls
y8vtec423
ok so im gunna swap my y7 for a ls b18 which is obd1 and im gunna use my engine harness since its non vtec. i know im going to need a jumper harness, is there any other wireing im going to have to do for it other then the injector clips?
vjf915
You are going to use your wiring harness from your D16 for your B18? Is that how Im understanding it?
saint1
u might need to wire the IAC which is a 4 wire on your harness and a 3 wire for the b18. other than that i think your set to go. i did the same as you, i used my y7 harness for my b18
saint1
you're doing an ls swap. then it might be a 2 wire. u might wanna look it up but u will need the connector.just search for ecu pinouts
